RE: Graupner Zlin Z-50LX ARF
I'm back. The dimensions that you gave me should work with little or no modifying the battery compartment. Of course until you know where the battery has to be located for proper CG, there could be some modification. The quality of this kit is very good. The only issue I've come across is if you want to change the color scheme. The covering doesn't want to take another covering on top of it very well. I've had to spot glue the added covering in places. So I didn't get as good of results as anticipated. Here is the latest picture of the Zlin's progress.
