RCU Forums - View Single Post - G26 Problem - Help Please
Old 06-12-2004 | 02:25 PM
Antique's Avatar
Antique
Default RE: G26 Problem - Help Please
Makes no difference which way the hole faces, it's for atmospheric pressure to operate the diaphragm...You could make a small plate to deflect air from the hole...A cover made from an aluminum can the size of the plate and spaced with washers under the screws works good...If it looses power except when climbing the high speed is too rich...
