Pull Pull Systems
It doesn't matter, either way. I do suggest that you run some nylon guide lines inside the fuselage though, as you may have to restring the line at some time. The nylon guides also help in the exit openings (easier to have a nice clean outlet) and prevents the line from cutting into the covering at the exit.
