RCU Forums - View Single Post - Choking a Ryobi Engine
Old 06-12-2004 | 06:08 PM
teufelhund's Avatar
teufelhund
Default RE: Choking a Ryobi Engine
Definately unplug the primer bulb and use it. It is much easier to prime the engine in this way. Do you have a velocity stack on the carb? If not, you could get one, it could help priming to because you have a better area to get your thumb over. Is the primer bulb attached to the carb? If not move it to a more convenient location. Good luck and happy flying!
