RCU Forums - View Single Post - Solo'd first day at the field !
Old 06-12-2004 | 10:48 PM
высшее одно
Default RE: Solo'd first day at the field !
good job, i have the same plane, but i put a .46 in it, it flys alot better and you can do more with it, but that is alittle later on, but if you do, if you move the battery back dont run the wire through the servos, it killed my plane four days ago, the servo unplugged the battery and went full throttel strait into the ground, crushed the inside of the wings, broke the firewall, cracked the fuse., but i should have it up by next weekend, asumeing the engine runs
