RE: Citabria Pro by Balsa USA
Mine aren't glued in and fit pretty tightly in the holes, the front mounts are tight but the rear are loose enough to rotate. Once the wing is bolted in place they don't move at all so there are no issues with them comming out while in the air. The only thing I have an issue with is that the back mounts will rotate around with the wing off the plane which can be annoying when it comes time to mount the wing.
