RCU Forums - View Single Post - Engine Overkill
Old 06-13-2004 | 06:57 AM
greenboot
Default RE: Engine Overkill
It is normal for the fuel line to pull off easily. That is how you add fuel. If it sort of falls off, it could be either too big or worn out. Try a new piece of the correct diameter. You should be using the medium diameter.
Tom
