RCU Forums - View Single Post - Phoenix Sonic 25 Low Wing ARF
Old 06-13-2004 | 03:05 PM
  #38
electron's Avatar
electron
Default RE: Phoenix Sonic 25 Low Wing ARF
Should not be a problem to use the two fingers as a CG balancer, thats how I did mine... Are you checking without fuel then with fuel, because the CG shouldn't change...
You want the plane to balance at the CG point or even 1/4" nose heavy is good...
