RCU Forums - View Single Post - Kyosho PT17 Stearman
Old 06-13-2004 | 07:52 PM
jbrundt
Default RE: Kyosho PT17 Stearman
ORIGINAL: drvwaymech
also, has anyone had any luck locating matching covering for the PT 17? Mine has a ground ding on the wing and the closest that I could come to matching is not close. ruins an otherwise beautiful airplane. Need info on replacement parts and need to match the motor mounts since I may reengine it and do not want to grind and redrill the originals in case I want to switch back. I cannot believe that a plane that is so beautifully engineered and well built has so few replacement parts and unmatchable covering. Have been dealing with Tower and maybe am looking in the wrong place. thanks
I covered the fuse of my Kyosho Stearman with Cub Yellow monokote and it's a dead match for the yellow used on the wings. Not sure why you'd be having a problem.
If you want visit my site in the link a few posts up.
Jeff
