RCU Forums - View Single Post - Bizzar Problem, Need Advice!
Old 06-13-2004 | 09:31 PM
FlyingFish
My Feedback: (17)
Default Bizzar Problem, Need Advice!
I have a Corona 120 Helicopter Brushed system, Stock Fusion 7 motor & Fusion 35 ESC, w/ 7 cell 2400 mAh Battery pack. Everything was working fine until one day the whole system was dead, No Servo, No Motor, Nothing!!! I figured that The Castle Creations Speed control burned out, So I switched to a Mega Brushless Motor and Matching Phoenix 35 Speed Control, STILL DEAD NOTHING WORKS!, Then I accidently found out That if I HOLD THE TRANSMITTER ANTENNA OR MAKE ANY BODY CONTACT WITH THE TRANSMITTER ANTENNA, THEN EVERYTHING WORKS NORMAL!!!!!!!! I even hooked up the Old Fusion 7 motor & Fusion 35 Speed control again, IT WORKS PERFECT NOW,SO LONG AS I HOLD THE TRANMITTER ANTENNA, BUT IF I TAKE MY HAND OFF THE TRANSMITTER ANTENNA, DEAD, NOTHING AGAIN!!! What the Heck is that all about, Do I need a new Transmitter, Im using a AIRTRONICS RD 6000 with L.E.D. Screen.
Any Suggestions would be appreciated..........[&:]
P.S. My Transmitter & Battery pack are Charged Full.
