RE: Realflight Crashes on Startup in Windows XP
If you haven't already, try un-installing and re-installing the software. This will often fix problems of that nature because the corrupt file(s) will be replaced with a valid copy from the cdrom as it installs, and registry entries will be recreated. It may not fix it, but it is easy to try and costs nothing.
good luck
