Keeping the muffler on
Thanks for the tip!
If you alter the rpm slightly you can improve on the shake problem. Sometimes moving the peak rpm 2 or 300 one way or the other helps a great deal. Try a different prop size.
Also make sure that you are not running the engine too lean.
Good Flying,
Dave
