RCU Forums - View Single Post - YS63 Regulator Question
Old 07-10-2002 | 12:50 PM
visioneer_one
My Feedback: (506)
Default YS63 Regulator Question
Originally posted by antispad
I didn't see a thing!
Has YS chanced the plunger? Mine looks like silicone on the spring side, and a brass plate on the motor side. I couldn't figure how to take it apart.
It doesn't take a big chunk in there to upset the regulator. A small sliver of plastic swarf from your fuel tank is all it takes.
The silicone bit is press-fitted onto the brass plunger (and is a PITA to find if you drop it, so be careful!) As long as you've flushed the regulator body out with alcohol or fuel you should be OK. Make sure you don't snag the diaphragm when you reattach the regulator assembly.
