RE: GasZenoah 26 engine in plane causing rf glitching HELP!!!
crashland, I thought you had already changed out everything one component at a time. That may be the only real way to find the problem.
obolel, I stand by my earlier remarks that if you have to go PCM to get range you are not doing anything except masking the problem. Find and fix the problem.
Ed M.
