I used a long drill bit, inserted the nyrod tube, then taped a small brush to a length of dowel rod to apply the epoxy. Just make sure you get a good bit of epoxy on the brush and you will be okay. The first time I did a conversion on the LT40, I just ran the rod out the side of the fuse. Didnt look as pretty, but it did the job very well.
