[link=http://www.imagestation.com/album/?id=4286547669]Imagestation Album[/link]
HMMM those don't seem to work.[&o] ahh ic ic now you have to log into imagestation first.
It uses semi proportional differetial thrust steering and can turn around its axis. The large chunk of foam on the front is so if it sinks it won't go all the way under. It has a slow leak in the back where i tried an under water propellor setup so i tried to stop it with one of those (proud honor student parents bumper sticker) but it still leaks. It can make it over some nice sized waves with out capsizing and can go in easily go in ponds only inches deep. It's batteries are 2 (4.8V 1500mah) packs wired in parralel for 3000 mah of capacity it runs for around an hour quite quickly for the cruddy design
