RCU Forums - View Single Post - Newbie with an Edge 540
Old 06-15-2004 | 12:58 PM
plivez
Default RE: Newbie with an Edge 540
Balls!!!
Engine cut again at low throttle, I couldn't turn to the field in time and just had to try and land it blind behind a hedge[X(]
Well I was lucky as you can see, it hit a wire in a vineyard which took the force of the crash. Only damage is to the wing locator and mounting.
So will be back in the air this weekend.
I have had two contradictory pieces of advice re the low idle problem.
My model shop recommends trying a hotter plug as it may be running too cool.
The distributor recommended more oil content in the fuel.
Anyway I shall be trying a hotter plug Enya No 3 this weekend
http://homepage.ntlworld.com/peter.l...rst-flight.jpg
http://homepage.ntlworld.com/peter.l.../edgecrash.jpg
