RCU Forums - View Single Post - SIG easy hinges?
Old 06-15-2004 | 10:34 PM
wildthing7037's Avatar
wildthing7037
Default RE: SIG easy hinges?
Hi,
Try not to put them in and out of the slot you cut too often, as eventually the fuzzy cloth stuff will peel away from the mylar. You want them to pretty flexible to work as a hinge.
The instructions on the back are very good to follow. Remember when gluing them with thin CA, glue both sides. I have used them on fun flys to pylon racers without a singel failure yet.
Stefan
