RE: Flaperons or not?
I wouldn
t bother with flapperons on the GBM Cub either. If, however you find it needs a little help, turn both aireron clevises in two turns. this will drop the ailerons a tiny bit to act as flaps.
Also, use an incidence meter. make sure that with the wing at ZERO, the tops of the floats are at about -2 degrees.
