RCU Forums - View Single Post - DA-50 snag and need some help
Old 06-16-2004 | 09:48 AM
MustangFan
Default RE: DA-50 snag and need some help
Since I had many problems with ignition modules, I ask DA directly if the statement in the "manual" was correct concerning not using BELOW 5.0 vdc OR ABOVE 6.0 vdc.
I was told the module had a greater voltage range than stated, and I need not worry about a 4.8 volt battery or using a 5 cell pack without a regulator. I'm using a 4 cell pack.
Yes the module will spark when the crankshaft is turned ... all you need to do is move the hub back and forth quickly making sure the magnet passes the sensor. Also make sure the sensor is plugged in with the wire color coding lined up ( A message I got from DA).
Now that I have a good module ... no problems have been encountered ! Starting by hand now ... my arm has healed.
Hope this helps !
Good Luck
