RCU Forums - View Single Post - DA-50 snag and need some help
Old 06-16-2004 | 10:47 AM
rfw1953
Default RE: DA-50 snag and need some help
Well darn, Howard.........Now you have me second guessing the problem. I for sure was not getting a spark and I had used the Megatron starter so it was turning over big time while as I held the plug with insulated pliers on the jug. Yes the wiring was plugged in properly. There was no spark at any time that I tried this, even after cleaning the plug and allowing to dry out. My only hope right now is that the plug was fouled even after cleaning and allowing to dry, which has me wondering.
I'm using a Deluxe JR charge jack switch so I wonder if this too could be a problem. I have attached a picture of the switch used below.
cummings66 raises a good question about why these plugs are so sensitive once fouled. I wish I knew the answer. Anyway, I ordered two of them. Whats interesting is that when I talked with DA they told me that plugs going bad is a pretty rare thing. I don't know, but I will learn from this experience for sure, which is what it's all about.
