RCU Forums - View Single Post - Hinge Points with Foam-Core Wings?
Old 06-16-2004 | 11:49 AM
Tired Old Man
Default RE: Hinge Points with Foam-Core Wings?
Depending on how much ca you used, you can have from a small to a very large void inside the wing. It's best to fill this void back up if at all possible. A good material to do this with is expanding insualtion foam that you can get in a spray can at the hardware store.
Test a small piece of foam for compatability, and if it's ok, squirt in a very small amount of the foam and let it expand and set up. Trim off any excess and install your hinge.
