RCU Forums - View Single Post - Stuck Screws
Thread: Stuck Screws
Old 06-16-2004 | 11:56 AM
DarZeelon's Avatar
DarZeelon
Default RE: Stuck Screws
Nate,
Heat might work to loosen the head bolts.
However, since Aluminium expands more than steel, the bolts may be significantly tighter, if you try to open them while the head is hot.
Your engine has what I believe to be Metric bolt sizes. An imperial (inch) Allen wrench will not fit, and potentially could destroy the sockets. Take notice!
