RE: SIG easy hinges?
Placing the hinges in the grooves prior to gluing is the correct method. You must use thin CA so that it wicks into the joint. If you stick a t-pin through the middle of the hinge it guarantees that it is centered in the two pieces, and you can run the CA down the pin.
Kerry
