Engine Dies when nose lifted
I would start from the basic fuel line connections (as well as pressure line) and go to the mixture settings, etc. The vibration could be things like prop (don't know if you replaced it or if it broke), a crack in the nose somewhere or firewall, etc.
May be worthwhile to pull the engine and check the mount structure.
Good luck!
Mike
