RCU Forums - View Single Post - What is an autorotation?
Old 06-17-2004 | 09:26 AM
Spaceman Spiff
Default RE: What is an autorotation?
you define any level, but it is intended to be idle. handy that you can set it to any level give it half throttle so you can just about hover if you need to, so you can go thru the motions of an auto without the risk. do that a few times them start backing the setting down a few clicks at a time till it is down to idle.
