Engine Dies when nose lifted
You should be able to pull the tank out of the plane, it just slides in on a superstar. Check and make sure that your clunk is in the back of the tank, no cuts or holes in your fuel tank. If you are sure that your prop is balanced, you might have bent the crank when you hit the tree. Also check around the carb for cracks in the case. It could be sucking air through the case. good luck
