RCU Forums - View Single Post - first warbird - third plane?
Old 06-17-2004 | 09:56 AM
w0mbat's Avatar
w0mbat
Default RE: first warbird - third plane?
We don't recommend our warbird kits for a first time builder. They are very easy to frame up but they are fully sheeted - which is the most difficult part of building. We don't explain how to sheet a plane, although we do give instructions on how to apply the sheeting to the different areas so it will lay correctly. We also don't go into detail about installing servos, receiver, battery pack, fuel tank and engine. You can download our instruction manuals on our website if you want to take a look for yourself. The Val and ME109E are the newest kits and will have the most complete manuals. If you are still considering one after reading over the manual, I would stay away from the Stuka, Dauntless and the Avenger - they are the most difficult to build because of flaps and other more complex areas. Otherwise, our kits all build using the same techniques.
Mike Grey
Skyshark R/C
