RCU Forums - View Single Post - Engine Dies when nose lifted
Old 07-11-2002 | 05:53 PM
hoppy
Default Engine Dies when nose lifted
Randy,
I replaced the prop with the same type of wooden prop that it had, (topflite or something like that). I did balance it...
I see air bubbles in the line as I tilt the plane up. You said that means it's sucking air so does that mean there is probably a problem with the fuel tank?
Thanks for the help.
