Engine Dies when nose lifted
Good ok now we are getting somewhere. Yes you definitely have a problem in the tank/line area. If you can get to the tubing try that first replace the feed line and might as well replace the vent line as well with some medium tubing. Give it another try and if that does not help then I am afraid that your tank will need attention.
Another question do you see fuel on the balsa inside the fuse itself under the tank?
