RCU Forums - View Single Post - Engine Dies when nose lifted
Old 07-11-2002 | 06:23 PM
rcflier_gi
Default Engine Dies when nose lifted
Originally posted by Tony Hoppenrath
blackie,
I can't see under the tank the blasted firewall is in the way. (not at the plane now though). Will I have to cut the firewall out to get to it?
If I just replace the lines, by vent line do you mean the one that goes to the muffler? I will have to pull the engine correct? (so I can get the lines on the tank)
The tank should come in and out through the back (the access area where the wing usually rests). You shouldn't have to cut the firewall to remove the tank.
