RCU Forums - View Single Post - RV-4 progress
Old 06-17-2004 | 12:14 PM
barto's Avatar
barto
Default RE: RV-4 progress
I have build one as a second kit. I found it very easy to build, it's not perfect for a first build but it's ok I think.
There are just lots of things you learn by building kits, you will make some mistakes (that's mostlikely) but everyone has that. It would be good to have someone with experience to help you, that will make it easiere. The manual is very detailed, with much pics and good explanation.
Just make sure you don't build to left sides, also, watch out because the fuse it build upside down (or atleast I think it was). Just double check everything before you put glue on it, regularly have it checked out by your instructor or someone that can help.
Have a good time building
