RE: How do you hover a plane?
Here is the sucky thing about "trying" to hover a plane. First you need to have the plane a couple of mistakes high. Second you are probably using a 40 size to learn with. Third I can not for the life of me figure out when the plane is falling out before its to late and then I end up "trying" to keep my plane from digging a hole in the ground. It sucks that you need to have your plane that high to learn because you just can't see what it's doing well. I guess I will keep trying.
Trying is a word I seam to use a lot.
