RCU Forums - View Single Post - two blade prop for alpha
Old 06-17-2004 | 01:57 PM
jettstarblue's Avatar
jettstarblue
Default RE: two blade prop for alpha
I left the flywheel on, and use a Higley aluminum hub. Dubro also makes a "spinner nut" that works nicely.
You can also opt to just not use a spinner, put on the prop, then the washer, then the nut, and go fly.
No, I wouldn't fly it with the backplate warped, you're asking for trouble.
