RCU Forums - View Single Post - MUST use epoxy?
Old 06-17-2004 | 02:09 PM
Mike in DC
Default RE: MUST use epoxy?
ORIGINAL: bryris
However, I am also wrapping a 3" wide piece of fiberglass tape around the wing section and epoxying it into position with 45 min epoxy. Hopefully, I'll be OK.
This is not really a fair test of the wood glue. The fiberglass tape and epoxy is 1,000 times stronger than the wood glue joint. I can assure you the wood glue joint will never fail.
