RE: Model Tech Magic
Hi varun, i have a magic extra, in my opinnion it's a good plane if you look at low cost model. i use a OS 46FX with a 12.25X3.75 apc prop, i replace the stock wires ( they are too heavy for the servos and make the plane unstable at high speed) for a pull pull system from du-bro, the plane hovers at 1/2 of throtle and make a lot of 3D maneuvers the flat spins at great. you can sometime I land with a flat spin (well i lost my rudder in the air jejeje) but the plane don't hurt.
in the construction you put some reinforcement for the rudder, i lost mine in the air. thats the ondy thing i found worst.
it a good plane i recomend too much.
Luis
