RCU Forums - View Single Post - MUST use epoxy?
Old 06-17-2004 | 04:52 PM
Rodney
Default RE: MUST use epoxy?
If you have a good fitting joint, wood glue is ever bit as good as slow epoxy and much better than 5 minute epoxy. I've put many a 1/4 scale together with nothing but wood glue with never a joint failure. The necessity for epoxy use is much over rated . A good wood glue joint will be stronger than the wood and much stronger than a poorly made epoxy joint.
