ORIGINAL: p51flier
I reinforced some ABS part inside with a light layer of glass sucked with acetone. It made the glass sink into the ABS. That method worked quite good. Instead of actone I also used thin CA.
The only negative I have found to acetone is that if you use too much, it can "melt" through the ABS piece and/or warp it.
