RE: MUST use epoxy?
Spokman, if you really check you will find most wood glues (all that I know of) are much more flexable than the epoxies and hold up much better under shock loads (hard landing or crashes) as well as vibration. Also, clamping is not necessary on a good fitting joint; however, you must leave it unmoved while it is setting up just as you do the epoxies if you want a strong joint.
