RCU Forums - View Single Post - OS 46 LA problem continues, with head picture
Old 06-18-2004 | 09:11 PM
Live Wire's Avatar
Live Wire
Default RE: OS 46 LA problem continues, with head picture
Bad O ring on needle valve, Air in fuel line means that you are getting air past the O ring and not getting fuel from the tank, it will idle great but get hot and stall or quite at high RPM. Could cause damage to engine cylinder and piston.
