RE: Converting my alpha to a tail drager?
I think the Alpha's tail section is designed much like the LT40, with the vertical stab and rudder on top of the fuse. In that case, the best way to convert to a steerable tailwheel is to run another pushrod, or a pull-pull system off the rudder servo, to the tailwheel. This eliminates having to rig up a way to connect the tailwheel directly to the rudder itself.
