RCU Forums - View Single Post - GSP Zero
Thread: GSP Zero
Old 06-21-2004 | 10:58 AM
SJN
Default RE: GSP Zero
Well, this is how it looks now.
Im using eurokit air/spring retracts, and they are 25mm wide, where the mounts are only 20mm wide.
I have then removed 5mm of the mount to fit the unit.
I have to order some longer and a bit different lookin oleo strust so it will look good.
The 6mm steel pin that connect the strut to the retract unit has to be bent forward so it all fits nicely together.
Do you guys thenk the 90 is too small?
HAve a look at the specs: http://www.webra-austria.at/motor.ph...r=AERO&lang=EN
