If only I had two cents!!!
Wings, the prices are on the web site, their are a number of options. Basic price ($229) includes motor + two micro servo's. You can buy a package including tx, rx, batteries and charger.
If you were to use your own radio, then weight is an issue so the Rx needs to be a minature. I'm using a GWS 4N (from memory). Standard Tx is fine, but rates would be an advantage for the 'rudder' function as the tail is mounted directly on the servo, so you can't adjust its movement by linkages.
Hi 75 lover, the Cybird comes with a CD-ROM showing it in flight, the video on the racing devils site is taken from that.
I've just ordered the Lithium cells, be in touch when I'm up and running again.
Ted
