RE: u-can-do 60
Got another question you guys. I'm debating using a fuel valve again on my 160 for the Soucy, or just using a fuel dot? here is the question. Do you guys use the third hole as your refill line to the he tank or use a T off the fuel draw line to the carb? If off the fuel draw line to the carb how do you avoid flooding the carb without pinching off the line to the carb? I think the answer is to simply use the third hole, which is not tapped and simple to do. I honestly have only used fuel valves in the past and would think you put a clunk the third line for refueling. yes? No? trying to keep the weight down so thinking of using a fuel dot.
