ORIGINAL: RoNeRiC
Pull the fuel line and put the glow starter on and burn up the fuel left in the line,carb, and cylinder.
Just my point, all the fuel in the engine is oil at that point. You start it, run it out, the engine is then running with no oil in it. Thats why all the guys I know that do it are always replacing bearings. The guys that don't do it, don't ever have to replace bearings. Would you run all the oil out of your car when you change it? I hope not. Why run it out of your plane?
