RE: Do Engines Create Thrust, or Do Props Create Thrust?
Fox MFG is the only MFG that I'm aware of that says their engine will turn a certain prop at a certain rpm, for example they say that the Eagle .74 will turn a 12x8 at 11,200 rpm and it does precisely that. The .60 turns the same prop at 11,000.
