ORIGINAL: rcdude37
and back to flyboy's saying
drain the oil out of your car and start it, you will damage the piston, sleeve and other parts the only reason they tell you to run the fuel out is so it dont gum up, if you are going to start them within the next week they won't do that, heck i let mine sit without running it out for months and it starts right up.
im not saying its bad to run the fuel out of the engine but if the shaft turns the piston is going to move if there is no lube inside its going to scratch something
I'm just posting what the manual says. I trust O.S. engineers not to lead me wrong. There is lube inside. It's not bone dry. Take your head off and look inside. There is oil still on everything. As long as it has enough to coat the parts it will not hurt it. Even a car will run for 10 minutes with the oil drained because there is still oil on everything. Heck maybe even longer.
"Drain the oil out of your car and start it." It will run until "heat" gets the piston and cylinder too hot and it wil seize. The oil is not just there to lube everything but also to take the heat away form the parts and cool them. Yes, I will agree with you that if it is RUNNING without no lube it will damage the parts. But when I start it it has the after run coating all over the piston,cylinder and crank.
This could go on forever. Some people use after run and some people don't. Some say they use it and no problems and some say they don't and no problems. Maybe they are both right because it doesn't matter either way. Just do what gives you peace of mind.
