RCU Forums - View Single Post - prop size
Thread: prop size
Old 06-22-2004 | 10:37 AM
Campy's Avatar
Campy
Default RE: prop size
If your engine is a 40, the 10x6 will be fine.
If your have a 46, I suggest an 11x6 prop.
The Master Airscrew props (the black ones with the squared off tips) are usually best for a trainer as they are less efficient and will allow the plane to fly a little slower (they also are less susceptible to breaking if you hit a tip on the ground). As your skill improves, you may want to consider going to the APC brand of prop (gray with a tapered, rounded tip). The APC props are more efficient and will thus let the plane fly faster.
