RE: Plane Continues to Climb?
RE: Plane Continues to Climb? (in reply to GarMan) Report This Post | (Post No. 8)
I cannot move my wing back any more to adjust CG. I could (but don't want to) add angle down. This might be the easiest.
ok,,,,wait....you dont move the wing to get the CG right..you have to balance the model ON the CG.....if its a constant wing...(no sweep)...put a mark on the wing 25% of the chord...if the wing is 12 inches put a mark 4 inches back from the leading edge...and theres your balance...you dont move the wing bud....hope this helps....min. setting balance is 25% max is 33%,,,but the 33% is for real touch'y feel of the elevator...please dont do this right away...as you might not be able to handle it...good luck bud...Rod
