RE: BME 50
Yes, but mine turned out to be a bad ignition switch that would only show up after some heat was generated in flight, maybe 3-5 minutes into the flight. Their customer service is great and I followed all their suggestions and tracked the problem down. Reciently had a high speed problem that they think is the hall effect sensor and it should be here tomorrow. I had used a Great Planes ignition switch that I mounted up front, they don't seem to like heat, replaced the switch and moved it away from heat and no problem since.
